Disables the MAC address withdrawal capability.
| l2vpn | Designates L2 VPN configuration. |
| vpls | Designates VPLS of MPLS configuration. |
| peer | Designates VPLS peer. |
| ipaddress | Selects the VPLS peer of the provided IP address. |
| all | Selects all VPLS peers. |
| fdb | Designates FDB. |
| send-mac-withdrawal | Disables sending the MAC address withdrawal message. |
Enabled.
When disabled, the switch does not send MAC address withdrawal messages. If a MAC address withdrawal message is received from another VPLS peer, the local peer processes the message and withdraws the specified MAC addresses from its FDB, regardless of the MAC address withdrawal configuration.
The following command disables MAC address withdrawal message for all VPLS peers:
# disable l2vpn vpls peer all fdb send-mac-withdrawal
The l2vpn keyword was added in ExtremeXOS 12.4.
This command is available only on the platforms that support MPLS as described in the Switch Engine v33.1.1 Licensing Guide document.
